587,218 active members*
2,587 visitors online*
    Oct 2005
    332
    Change language of 21i-m
    Hello to all.
    I have bought an used unpowered machine with fanuc 21i-m. The controller powers on, and some errors appear related to the battery power down (error nº 300). I have replaced the batterys and I am looking for a procedure to reset the axis to the correct position.
    But before that I need to change the language of the controller. Currently it is in Spanish and I would like to have it in English. I must confess that I do not have experience with this controller, so be kind on explanations.
    I have found the parameter to change languages, and when I try to replace the bit from 1 to 0 I receive a flashing error, that PROBABLY says in spanish protected. I have put PWE=1 before, so I really do not know what to do more.
    Thank you
    2932
    #3102 = all 0's (bit 6 = 1 for Spanish)
    #3119 bit 1 = 0
    #3190 bit 3 = 0
    Oct 2005
    332
    Thank you dcoupar;
    it is done! I will try now to solve the battery replacement.
  1. Mo Language change
    By greenery_fr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-18-2016, 01:53 PM
  2. language change on meldas 65-M
    By scale in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-23-2008, 10:22 AM
  3. Change language in Hypermill
    By ltech2020 in forum Hypermill
    Last Post: 08-07-2008, 03:29 AM
  4. Language change on Mazatrol Cam T2
    By andreypav in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-14-2008, 03:23 AM
