586,523 active members*
3,500 visitors online*
IndustryArena Forum: Centroid CNC Control Products
Page 11 of 19 910111213
Threads 201 to 220 of 379
Discuss Centroid CNC Control Products, systems and project here!
  1. Ajax CNC11 with 4th axis
    Started by dougputt, 12-31-2014 07:37 PM
    axis, brake, cnc, pause, program, similar
    01-07-2015, 01:25 AM Go to last post
    01-02-2015, 02:11 AM Go to last post
  2. Bridgeport S2I2 Head Control
    Started by Jay Kyle, 12-18-2014 01:16 AM
    add, ajax, bridgeport, buttons, buy, con, control, conversion, cycle, feed, head, hiring, ideas, learn, plc, site, star, time, tons, tool, version
    12-19-2014, 02:19 AM Go to last post
  3. servo spindle
    Started by ghack, 11-23-2014 04:10 PM
    12-08-2014, 03:57 PM Go to last post
  4. Lathe conversion
    Started by ghack, 11-06-2014 02:10 PM
    back, c10, cnc, cnc1, conversion, ing, lathe, lathe conversion, long, odd, recommendations, required, run, setup, specs, tape, time, turn, version, vfd, wondering
    11-07-2014, 08:08 AM Go to last post
  5. Ajax cnc10
    Started by ghack, 11-02-2014 04:04 PM
    ajax, c10, cnc, cnc10, converted, couple, current, drive, fine, ideas, linux, load, made, mill, problems, program, reinstall, short, software, ssd, stall, time
    11-05-2014, 05:19 AM Go to last post
  6. Turning spindle on reboots computer
    Started by Scoot, 10-21-2014 03:04 PM
    art, centroid, computer, control, converter, error, full, issue, machine, motion, phase, phase converter, power, reboots, run, running, spindle, star, start, suggestions, turning, ycm
    10-23-2014, 06:20 PM Go to last post
    09-25-2014, 12:19 PM Go to last post
  7. Shizuoka AN-S Ajax Retrofit?
    Started by voiceafx, 07-25-2014 04:04 PM
    ajax, alter, alterna, alternative, cnc, cnc controller, comments, controller, fix, good, hardware, king, mach3, machine, retrofit, roller, shadow, shizuoka, solution, thinking, upgrade
    07-25-2014, 04:04 PM Go to last post
  8. Encoder reading from AC/DC drives.
    Started by howanc7, 06-16-2014 12:58 PM
    ac/dc, drives, encoders, guide, mpu11
    06-16-2014, 06:46 PM Go to last post
    05-19-2014, 04:36 PM Go to last post
  9. Centroid Operator Manual
    Started by howanc7, 05-01-2014 06:55 AM
    centroid, load, manual, operator, set, set up, system, version, wrong
    05-01-2014, 01:45 PM Go to last post
  10. GP104D Inputs
    Started by howanc7, 04-17-2014 08:55 AM
    address, ajax, axis, buying, check, computer, drive, fanuc, fault, feed, input, light, low, motors, power, relays, retrofit, running, screen, sense, set up, terminal, time, wiring, work
    04-20-2014, 06:09 AM Go to last post
  11. E-Stop on axis motor wiring.
    Started by howanc7, 03-07-2014 04:08 AM
    axis, broke, broken, cables, diagram, drivers, e-stop, free, motor, motors, shows, sta, stop, wires, wiring, wiring diagram
    03-08-2014, 08:25 PM Go to last post
  12. E-Stop and coil voltages.
    Started by howanc7, 03-05-2014 02:57 AM
    axis, capacitor, circuit, coil, drawing, drives, e-stop, film, fit, hydraulic, input, issues, led, machine, motor, nec, parallel, parts, plc, relays, show, supply, wire, z axis, z axis motor
    03-07-2014, 04:03 AM Go to last post
  13. Ajax Centroid, MPU11, inputs.
    Started by howanc7, 03-03-2014 12:02 PM
    add, ajax, centroid, circuit, circuit diagram, component, controler, current, diagram, e-stop, fanuc, input, king, lathe, limit, limit switches, output, rectifier, retrofit, retrofitting, stop, swi, tolerance, volts, wire
    03-05-2014, 02:22 AM Go to last post
    01-16-2014, 07:05 PM Go to last post
    01-11-2014, 03:01 AM Go to last post
    12-05-2013, 06:59 PM Go to last post
  14. Unhappy centroid M400 issues
    Started by Ernie, 10-23-2013 01:54 AM
    10-25-2013, 03:24 PM Go to last post
Forum Information and Options
Users Browsing this Forum
There are currently 6 users browsing this forum. (0 members & 6 guests)
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
