This weekend I managed to spend a lot of time on making the corner brackets for the gantry and installing them. The wiggle factor seems to be about half what it was without the new brackets. I presume that the remainder is not going to be correctable and will depend on the cable system and two stepper drive system to take care of any remaining issues with the gantry not being rigid. The Y axis mechanical travel is now 50".
I also continued work on the table saw fence. I made the eccentric cam but haven't drilled and tapped a 1/2-13 hole for the handle shaft yet. There are some places that need tack welding to hold the part that slides on the box tube front rail to the underside of the fence tube. A small steel plate needs to be fabricated and a hole drilled in the vertical part to mount the plate onto a bolt so that the plate can swing as the cam is tightened and loosened. A window and pointer needs to be added to the front of the fence so that a measurement tape can be seen through the small window. The CAD drawing may make more sense than my description alone. I should have bought the Delta T-12 fence. This homebuild fence is becoming a lot more work than I had planned.
CarveOne
