587,801 active members*
3,487 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Can't figure something out???
Results 1 to 7 of 7
    Oct 2008
    64
    I've only been using Mcam 9.0 for 2 weeks now and can't figure something out.
    Please look at this file and in operations highlight all and verify the part.
    When it gets done go to the top view and the flats on the sides, the 45 deg
    angle sides aren't smooth. It looks like it is leaving a plateau on both sides.
    ? Why?
    Also why does it show some "scalloping" on the top edge where the radius is?
    #3 the top profile, instead of running this the way I have it can anyone tell me how to profile this going back and forth in the X axis and in Y from front to back instead of going around the whole part?
    Please let me know,
    Thanks,
    Brian
    Attached Files Attached Files
    Surface finish parallel should solve your problem, you can tighten up the step over to get a better surface finish, .01 with a 3/8 ball end mill should be about right.
    Mastercam Training Online
    Oct 2008
    64
    cool thanks,
    Did you take a look at the sides?
    I am not sure what you meant there, if you mean looking down from the top view, you see a triangular section at the right and left with scalloping. That problem will disappear with the parallel toolpath. Let me know if that's not it
    Oct 2008
    64
    If you run the outside profile so you can see the sides cut.
    Look at the flats on the side. (if you were in top view-they would
    be the flats that are facing up and out about 45 deg)
    After you run the profile and rotate the part you will see that the cut
    comes off the inside radius not smooth and the same going into the outside radius.
    Instead of a smooth transition it steps out a little.
    Why?
    Do you mean this?
    Its probably just a graphics issue, like this
    If so, click on the configure tab in verify
    and turn up the quality
    Oct 2008
    64
    Thank GOD,
    I've been sitting here off and on scratching my head about this.
    Thanks,
    Bud
  1. trying to figure out what i want.
    By smooth72 in forum Smithy
    Last Post: 08-25-2009, 06:26 PM
  2. Cant figure out how to do this part
    By macona in forum Mastercam
    Last Post: 08-15-2008, 03:37 AM
  3. Can someone help figure this out, please?
    By windrider in forum Mastercam
    Last Post: 08-25-2007, 04:19 AM
  4. Anyone figure out the EMCI.INI
    By anoel in forum LinuxCNC (formerly EMC2)
    Last Post: 09-23-2006, 07:43 AM
  5. Can't figure out why...
    By asher in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-25-2006, 04:15 AM
