586,042 active members*
3,608 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Cannot Set Stock
Results 1 to 5 of 5
    Mar 2007
    114
    Cannot Set Stock
    Im using Solidworks 2013 with Camworks 2012 and have a new issue. When I go to the Camworks feature tree and edit my machine, that works ok so I know its found the Tech DB ok, however when I go to modify the stock I get no pop up window and all the Camworks features grey out. I know the licence is good and can see that in the licence manager. All the Camworks features are there until I right click to modify the stock. Any thoughts ?
    Mar 2008
    111
    Re: Cannot Set Stock
    Have you had a dual monitor on there at all?
    The dialogue may be on the other screen still....
    Mar 2007
    114
    I have tried with both dual monitor and rebooting with only a single monitor, im convinced the window is open somewhere as I can do nothing when it happens, pressing escape closes the window I cant see and then I can carry out other functions again
    Mar 2008
    111
    Camworks does have a toolbar reset tool I'm not sure if it will help though in this case,
    It's in the camworks folder from the start menu, alternatively just reinstall the service pack.
    Your reseller may be able to help you too.
    Mar 2007
    114
    Tried it this morning with the original dual screen set up and up popped the stock manager window. Don't know why it did not appear on the second screen that I was using at home. I had gone through the detect screen process correctly before connecting and after disconnecting the screens. Thanks James for your suggestions
  1. V25 Stock Wizard : Solid Stock
    By aldepoalo in forum BobCad-Cam
    Last Post: 05-22-2013, 08:46 PM
  2. 7/12 stock to cnc
    By LeeWay in forum Vertical Mill, Lathe Project Log
    Last Post: 11-15-2012, 10:52 PM
  3. Stock
    By eliot15 in forum GibbsCAM
    Last Post: 08-05-2011, 09:45 PM
  4. STL Stock
    By Konstantin in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-25-2010, 07:08 PM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
