Hi, I did a quick search, but I couldn't find an answer...
Is it possible to mill a 70mm diameter, 100mm deep hole in a block of Al (6082) with an X-1 sized mill?
I've never used a boring head before, but from what I have read, you have to start with a full depth pilot hole, and then bore it out slowly. Does this really mean than on an X-1 I'd have to bore up from a 10mm drilled hole to 70mm using the boring tool, adjusting it a tiny fraction of a mm per pass? Or can I get some sort of long endmill and just rough out the hole, and then just bore the last few passes for accuracy?
Thanks.
