Chopper Drive as you refer to it is a method of current limiting. This is necessary when a power supply voltage higher than the rating of the motor is used. Current limiting resistors can also be used inplace of a chopper. Current limiting resistors will disipate heat and be large in wattage value if the power supply is significanly higher that the motor rating.
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
