hi, i have a small shed which has no electicity, could my generator run a desk top co2 laser, as i would love to have one in the shed
thanks
paul
thanks
paul
you could, but you need to be careful about generators and delicate electronics, as they are not the cleanest of electrical sources. Personally if i had to do that i would look to pick up a second hand computer UPS from ebay, as that should provide a nice clean output even if the generator doesnt. That said if running power lines properly from house to shed is a possiblility, that might be better in the long run.
It depends on the generator. If you have one that provides a filtered true sine wave it would be just the same as hooking to the grid - but few actually are.
I agree with daedalus, a cheap off line UPS would fix most potential issues.
The desktop lasers don't have very high power requirements so a cheap UPS designed for a PC would be just fine.
Zax.
