Hi, I built a home-made 4axis router couple of years ago with mach3 control, leadshine servo-stepper motors and NSK linear bearings. For breakout board I used purelogic PLC4x-G2 interface. Machine backlash can be as little as 0.01-0.02 mm when nuts are preloaded and set (measured with dial gauge), or 0.2-0.5 mm after many hours of hard work (but it can be set again in mather of minutes to 0.02 and hold it for a long time) . The reason I am telling all this is because PLC4X broke last month, and I replaced it for time being with cheap chinese BoB which I had in reserve if such an occasion happened. At first, I didn't notice any difference between work done with PLC4 and with chinese BoB, but when I started new batch of some enclosures I do for some electronics I noticed that lettering is not good at all! Some letters are crooked, letter O does not connect start point with end point, almost everything points out to backlash of 0.5mm or more where is none. When I started cutting openings in enclosure, I noticed that circles are not round, but actually diagonally oval. Those are three holes for LED diodes which are 5mm diameter, which should be circular and fit to diodes but are so crooked that they have become unusable as pristine condition enclosures.
Yes, I read all posts regarding circle not round question, search the internet in three languages, but nowhere I found problem similar to mine so if I missed it forgive me.
The facts are:
- No backlash (0.02mm, negligible)
- Circles used to be true couple of months ago when I was doing exact same work, so I know it is possible (even with more than 0.02 mm backlash)
- The same happens regardless of the working speed - when set to exact stop or in CV mode, even with CV dist. tolerance set to 0.1 and motor acceleration set up to 1000 mm/s. After many combinations of accelerations I managed to make the circle somewhat round, but it still isn't as it should be.
- Even with that 'round circle' settings, letter O which is the same size as the holes (5 mm wide) looks like spiral, every angled straight line looks like arc
- The only change on the machine was BoB, all other settings are the same.
The assumptions are
- Y axis lags behind X axis. Why would it do that? No clue..
..or - Chinese BoB is f.ing me from behind while hitting me in a head with one arm and pulling my ears with another!!
I want to know, is there a possibility that BoB is doing all that mentioned above? Everything is cleaned and lubed, minimum deflection, position following error on drivers not changed since it started working and even after hours of working it still hold the position and repeats every move perfectly, always!! The problem is that the moves (arcs?!) themselves are wrong and parabolic.
Help me, please! I want to upgrade to pokeys57cnc or smoothstepper, but I need to figure out what is going out right now before I do that and curse smoothstepper for something which is not its fault.
Thank you in advance, Jasmin.
