587,133 active members*
3,353 visitors online*
IndustryArena Forum > CAM Software > CamBam > cambam running under win 95
    Mar 2007
    50
    I am trying to get cambam to run under the windows 95 enviroment, because I want to use the program turbocnc in the dos enviroment,and win 95 or 98 lets me do that eaiser than the others. i cant get it to run. I dont know what im doing wrong. I had rather use the win 95 if i could... thanks
    Feb 2005
    521
    Quote Originally Posted by wantsout View Post
    CamBam requires the .NET framework 2 to work.
    I just came across this...
    http://msdn.microsoft.com/en-us/library/ms973853.aspx
    Which basically seems to rule out Windows 95 as an option.
    I sounds as though Windows 98 *should* be possible but I am not sure if anyone has got this working.
    Good luck! I would be very interested to hear how you get on.
    Mar 2007
    50
    windows 95
    I have updated my windows to windows XP, and now working on my cnc to run in that enviroment, fixing to try cambam with mach2/3, as soon as i order two motor controls. I think I will try the geckodrives because i have heard they are very reliable. even the centent CNO142/143 but i think there a little pricey...Thank you for you responds.
  1. what is CamBam?
    By cncadmin in forum CamBam
    Last Post: 05-02-2009, 01:41 AM
  2. Need Help With CamBAM
    By Ponchibego in forum CamBam
    Last Post: 08-01-2008, 03:49 AM
  3. cambam and Turbocnc
    By wantsout in forum CamBam
    Last Post: 10-15-2007, 09:15 AM
  4. CamBam is going to Texas ! (Oct 20-21)
    By 10bulls in forum CamBam
    Last Post: 10-04-2007, 11:08 AM
  5. Will CAMBAM run in Win 98 ?
    By epineh in forum CamBam
    Last Post: 08-03-2007, 06:50 AM
