587,568 active members*
3,290 visitors online*
IndustryArena Forum > CAM Software > CamBam > Cambam novice question
    May 2012
    0
    Apologies if this is in the wrong section.
    Hi all, I only just downloaded the cambam software and am trying to get to gripps with it. The problem I have is as follows: I drew up a simple drawing with a few circular pockets and a small bit of text engraving; all covered with just 2 tools, no problem. generated the tool paths, again no problem and produced the gcodes without issue, a sample below:
    O01003
    ( Made using CamBam - CamBam CNC Software )
    ( Macro 5 sample plate 11/21/2012 1:47:47 PM )
    ( T1 : 8.0 )
    ( T5 : 2.0 )
    G21 G90 G64 G40
    G0 Z3.0
    ( T1 : 8.0 )
    T1 M6
    ( Profile1 )
    G17
    M3 S1000
    G0 X48.5 Y30.0
    G1 F150.0 Z-1.0
    G2 F800.0 X35.75 Y22.6388 I-8.5 J0.0
    G2 Y37.3612 I4.25 J7.3612
    G2 X48.5 Y30.0 I4.25 J-7.3612
    G1 F150.0 Z-2.0
    The issue is though, that when I transferred it to our Haas mini mill, all the lines with G2 or G3 codes were somehow put inside brackets ( ) so the machine basically ignored these lines. I've tried a number of different programmes to do the transfer, incl: Cimco edit and EdytorNC. Tried using ISO, text file, options too but all the same and the maching follows the same path on all.
    Anybody any ideas as to where I might be going wrong? Any help would be greatly appreciated.
    Thanks,
    M.
    Feb 2005
    521
    If the Haas is rejecting the arc moves, then my suspicion would be that the arc center mode is incorrect.
    In CamBam, under the the Machining object properties you can set Arc Center Mode to Absolute or Incremental.
    Try changing this and regenerating g-code.
    Good luck!
    www.cambam.co.uk
    Dec 2010
    0
    wrong topic. delete.
  1. Novice cnc
    By zero00 in forum Australia, New Zealand Club House
    Last Post: 06-24-2011, 01:27 PM
  2. Novice Programmer
    By jonesr in forum Okuma
    Last Post: 06-27-2010, 10:42 AM
  3. novice questions....
    By SSN Vet in forum MetalWork Discussion
    Last Post: 02-16-2009, 05:24 PM
  4. Basic CNC code question from a novice
    By piaengr in forum Waterjet General Topics
    Last Post: 07-18-2008, 05:55 PM
  5. Novice to CNC
    By mattinker in forum Mechanical Calculations/Engineering Design
    Last Post: 11-27-2006, 08:27 PM
