587,935 active members*
3,735 visitors online*
Results 1 to 2 of 2
    Question Cam Clamps - CNC Wood Router
    I'm looking to cut out an assortment of spiral cam clamps for my T-Nut style spoil-board. Being new to CNC I did a lot of research but could not find any drawings or plans out there. Just a lot of discussion and theory.
    So I starting drawing up a simple design.
    Attachment 446034
    So the force perpendicular and arc center point moves depending where you are along the cam face. I understand only about 1/4 arc is usable.
    My question, where is it best to place the center pivot/axis?
    Is there a max ratio lift/rise for the camp?
    Is there a simple formula based on tried and true verse all the theory?
    35538
    Re: Cam Clamps - CNC Wood Router
    For mine, I just drew a 3" circle, and offset the center hole 1/4".
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Replies: 5
    Last Post: 12-27-2023, 10:22 AM
  2. Small CNC Wood Router VS Large CNC Wood Router
    By omnicnc in forum News Announcements
    Last Post: 03-16-2013, 06:25 AM
  3. Need parts: Gooseneck & Clip on clamps/screw bar clamps, padded
    By LordStDennis in forum RFQ (Request for Quote)
    Last Post: 06-28-2011, 12:07 AM
  4. CNC router using kee-klamp style clamps?
    By octothorp in forum DIY CNC Router Table Machines
    Last Post: 10-18-2006, 02:09 AM
