587,499 active members*
4,988 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Call home or message if program stop..
Results 1 to 4 of 4
    Jan 2011
    32
    Hello everyone, often I leave the milling machine to work alone and go home. Is there a program that if the milling machine stops for any problem, or Simply program finish i am warned by a call or by a message? Work on selca 4000 cnc with windows xp. Thanks to all
    Dec 2012
    192
    Re: Call home or message if program stop..
    Hello.
    While it is possible to do as you want I think it might be better to use an IP camera so that you can alway take a look at what your machine is actually doing at any given time. There are a number of low priced units on the market.
    Another posibility is to use a smart phone for the same purpose. There are a number of apps to do that. ALFRED is one.
    Using the camera you can also check your premises as there are units that you can rotate and tilt.
    I hope this helps.
    Regards.
    Jan 2011
    32
    Quote Originally Posted by BBMNet View Post
    Hello.
    I hope this helps.
    Regards.
    Thanks, but i Need a software
    Remote Light Stack interfaces directly with the existing real light stack with up to five (5) lights on the CNC machine. It turns those lights into e-mails or text messages that can remotely notify anyone with an e-mail address or SMS (texting) capable cell phone. It can also update a website in real-time reflecting the status of the lights. Unlike traditional auto-dialers and pagers, Remote Light Stack uses your network so it requires no additional phone line and can send multiple simultaneous notifications to different destinations instead of a single phone call or page.
    REMOTE MACHINING
    Ph/Fax 1-800-248-1817
    e-mail: [email protected]
  1. Replies: 4
    Last Post: 03-10-2018, 07:37 PM
  2. UCCNC Call Home (;-)
    By vmax549 in forum UCCNC Control Software
    Last Post: 11-17-2015, 04:24 PM
  3. Replies: 5
    Last Post: 09-26-2013, 08:49 AM
  4. Fanuc 11m call sub program
    By rick kroeze in forum Fanuc
    Last Post: 04-21-2012, 04:59 PM
  5. Replies: 5
    Last Post: 12-31-2011, 02:29 AM
