587,129 active members*
3,237 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > c-x contouring option vs y-axis lathe
Results 1 to 9 of 9
    Nov 2006
    51
    So, im looking into purchasing an okuma LB3000-SBB with milling option. making round parts with a variety of shaped flats, never know what the future hold though.
    Ive never used c-x contouring, but i like its price alot better then a lathe with y-axis, can all contouring be achieved with c-x option? open to everyone's thoughts/experiences.
    I know one advantage of y-axis is gang style tooling.
    Feb 2007
    711
    Re: c-x contouring option vs y-axis lathe
    here is a picture that shows the main difference (in my amateur opinion)
    gang tooling works on either configuration, and Y axis machine will do C axis operations, but not the other way around.
    Feb 2009
    6028
    There is no way to use gang tooling without the Y. C/X axis is ok for key slots if you can go full cutter depth, otherwise the bottom wont be flat. The other issue with C/X is doing something like a hex on the face of the part, you will get a small line in the center of the flat from C axis reversal. Still good for side holes/face holes.
    Aug 2011
    2517
    I have CX contouring and its pretty useless for real milling. there are just too many negatives. a lathe with live tools but no Y its really only useful for milling slots/flats on OD the same width as the cutter and for drilling holes on side and face.
    whats the price difference for the machine with a Y axis compared to without?
    Dec 2014
    10
    I currently program and operate an LB3000EX MWY, it has the Y axis and also a sub spindle. I can tell you that having the Y axis opens a whole different realm to what your machine will be capable of. only downside iv run into is the controls are kinda picky on the format of the code sometimes but seeing as I went from running a Romi EZPath to this thing, its kinda like skipping middle school so im sure I missed a few key classes.
    Apr 2015
    31
    Look into an okuma multus. I program an b200w 7 axis lathe and it does cx milling and y axis milling. It also has two chuckes And 190 degree swing on the turret(b axis)
    Aug 2011
    2517
    they're also a LOT more expensive than the LB3000EX MWY.....
    Apr 2015
    31
    Quote Originally Posted by fordav11 View Post
    True but they're worth it.
    Nov 2006
    51
    Awesome, thank you everyone, its much appreciated
    I think i will go with the Y-option, model: LB3000EXII-SBB MY
  1. 5-Axis Contouring
    By GregCo3000 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-08-2013, 11:34 PM
  2. A new 7x CNC Lathe & kit option online
    By Richard23 in forum Mini Lathe
    Last Post: 03-28-2013, 08:59 PM
  3. Contouring a face profile using lathe
    By cowpoke in forum Mastercam
    Last Post: 03-19-2010, 12:50 PM
  4. My Z-axis moves upward during 3D contouring
    By Khalid in forum WoodWorking Topics
    Last Post: 07-15-2008, 12:56 PM
  5. help...mini lathe option
    By yak in forum Mini Lathe
    Last Post: 12-06-2006, 04:31 PM
