The problem with a lot of the Chinese kits I've seen, are the steppers are quite often fairly high inductance, usually with good quality individual drivers, but are supplied with a power supply around half the recommended voltage. Use the generic Gecko PSU sizing equation of 32 x the square root of the inductance, to tell you how much voltage the steppers you see advertised really need. If they need 90v but are supplied with a 24/48v supply, you can see the obvious performance deficit.
On the other hand if you connect that same motor in parallel mode, the PSU would be fine, but you'd be doubling the current requirements.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
