0 active members*
2,983 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Broaching a square corner on a cnc mill
Results 1 to 2 of 2
    Aug 2008
    28
    I am looking to broach a square corner in A-36 Steel. The slot I am machining finishes 7/8 wide, 1-3/4" deep, 2" high. I am roughing the slot with a 5/8 rougher. I would like to cut the corners square and finish the sides with a 1/2" carbide finisher.I am running an old leadwell MCV 760XL VMC. The part is 16" long, so I want to lay them down rather than standing them up and trying to mill them.Any suggestions would be appreciated!
    Thanks!
    Dec 2011
    34
    Re: Broaching a square corner on a cnc mill
    If your machine has spindle orientation option you could put a broach w a round shank in the machine orientate the spindle to line up with your area of the square corner,and move z down and step,over .002 and repeat until final dimension is reached....if you have spindle orientation...thats all I got.thats a long way to put in a smaller tool and get the depth too
  1. Skipping the corner of a square??
    By drakesis in forum DIY CNC Router Table Machines
    Last Post: 07-01-2014, 05:54 PM
  2. broaching splines on a cnc haas mill
    By redridertwo in forum Material Machining Solutions
    Last Post: 11-08-2012, 03:57 PM
  3. Broaching on CNC Mill?
    By tkoden in forum Uncategorised MetalWorking Machines
    Last Post: 09-16-2011, 07:08 PM
  4. Radius on the corner of square stock
    By ErnieD in forum MetalWork Discussion
    Last Post: 03-31-2008, 03:35 AM
  5. How to put a radius on the outside corner of a square?
    By Xterrian in forum G-Code Programing
    Last Post: 10-13-2005, 02:21 PM
