587,163 active members*
3,638 visitors online*
    Nov 2009
    58
    Question Bridgport VMC760/20 w heidenhain Tnc2500
    Hello friends,
    I need some help, just replaced the TNC2500 v2 with the same in a Bridgport VMC760/20.
    I have all the parameters but the machine loses them after powerdown everytime.
    I have a new battery, and have checked with power off, 5vdc is present at the chips.
    It seems like there is a "reflash" step that I am not doing to flash the ROM, or something similar. Have not found any answers in the docs.
    Does anyone know if I am missing something?
    Also if anyone needs parameters for this sucker, Ive got ?all? of them.
    Thanks,
    Rob
    Nov 2008
    69
    Check the battery holder for oxidation.
    Pull out the batteries and clean the base. Worked for me.
    Jukka
    Jan 2009
    80
    Call Rick Antowiak at Heidenhain. 1-800-233-0388. He helped me a lot with my TNC problems.
    Kevin
  1. PC2100 CONTROLER ON VMC760
    By Tmiller in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-12-2009, 02:17 AM
  2. Heidenhain TNC2500 or TNC360 post
    By santosa in forum Post Processors for MC
    Last Post: 06-18-2009, 09:14 PM
  3. Heidenhain TNC2500 or TNC360 Teksoft Post Processor " G " code ISO
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2009, 05:51 PM
  4. bridgport vmc hdd failure
    By jke6113 in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2008, 11:34 PM
  5. Bridgeport VMC760/20 Z axis not positioning correctly for tool change
    By seano_78 in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2007, 09:38 PM
