We have a Bridgeport series II Boss 5 cnc converted to run Greecko box, our Y-axis motor went out and found a used motor (p/n 025805) and installed it. We have tried the motor and it will run for a quarter turn then stop..we have the jog set to move 1 inch on the Y-axis but but it barely moves the belt pulley only moves 1/4 turn. Also does the motor also act as a brake because once it tries to turn it locked up like the motor is trying to turn both directions, feels that way also. So i guess my question is what could be going on ..like bad encoder...or controller.
The old motor would run but the output shaft wont turn.
Thanks in advance..
