I just bought a bridgeport series 2 cnc boss 6 early 80s model. The machine powers up and the spindle runs and changes rpm through an air controler. Problem is no mater what I do I can not move any of the 3 axis with the control panel limit switches are working except the top two on the quill they check good with a meter but when you trip them by hand they will not set off the limit light on the control panel. I have both operator and programing manuals that explain how to power up and check system for errors and move or jog axis it shows no errors but still will not do anything. I have power at the stepper motors but no drive also if you try to turn the axis by hand with power on they are locked .With power off they will move freely. also I am also looking for a maintinece manual. Does anyone have any ideas how to fix this problem without doing a retrofit.
