Hi, i just bought a Series 2 Interact4 with a TNC 150 for next to nothing. I did however buy it with the knowledge that the spindle did not run. I was told it had to do with the spindle motor brushes and I believed this to be true as they were badly worn and starting to dig into the commutator. So I made some spacers and moved the brush pack up onto a pristine area on the commutator and put in some new brushes, I thought I was home free but as luck would have it the motor just hums and does not turn and come to find out the error light on the Contraves drive is lit. I removed the terminals from the motor and put 12 volts to the motor and it wants to turn so I figure the motor is good and something popped in the drive when the original brushes went to hell. Is there a thermal overload or possibly something as simple as a reset on the contraves drive that will get me up and running. All the fuses are good and the main contactor pulls in to give power to the drive. Any help is greatly appreciated.
Thanks,
Maxvic
