587,541 active members*
4,642 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > BRIDGEPORT INTERACT 2 SERIES 2 WITH HEIDENHAIN TNC 145
Results 1 to 4 of 4
    Mar 2011
    0
    Having problem with Bridgeport Interact 2 Series 2 with Heidenhain TNC 145.
    After power-up and when traversing through either X or Y the machine stops and the TNC displays "Gross Positioning Error B"
    Can anyone provide some pointers as to possible cause?
    Jan 2005
    1121
    how about some INFORMATION
    when did it last run, did you just buy it does it home correctly
    the complete story or you will get no useful answers
    Quote Originally Posted by tommo61 View Post
    Mar 2011
    0
    Gus,
    Thanks for your response.
    We have had the machine for a good number of years and it was working up until 3rd May this year when it came up with the problem.
    The previous day it had been in a programme and worked fine and then the next day it would not home correctly.
    Jan 2005
    1121
    If it happens at the end of the homing for the axis, I am going to imagine that the tach is not working or not connected. The control does not look for anything until the trip dog switches, then it tries to close the position loop
  1. Bridgeport Series 2 Interact 2 Heidenhain TNC 155
    By rrossey in forum Bridgeport / Hardinge Mills
    Last Post: 11-30-2023, 01:10 AM
  2. Getting Bridgeport Series II Interact 2/Heidenhain TNC 151 running
    By maxvdh in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2017, 09:25 AM
  3. Bridgeport Interact 4 Series 2 with Heidenhain TNC155
    By benspeed in forum Bridgeport / Hardinge Mills
    Last Post: 11-26-2012, 03:08 PM
  4. Bridgeport Interact 1 MK 2 Heidenhain 151
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 11-30-2011, 11:35 PM
  5. Interact Series 1 Mk2 Heidenhain 155 - Any have schematics?
    By MeTri in forum Bridgeport / Hardinge Mills
    Last Post: 08-13-2009, 01:09 AM
