587,468 active members*
3,524 visitors online*
Results 1 to 2 of 2
    Nov 2004
    239
    Bridgeport Interact 2 Series 2
    Problem with machine resetting with turning on the spindle. Machine will reset and come back with error "Short Current Interruption"
    Power machine on. Hit "CE" button. Hit yellow button. Hit the green button several time to get X, Y, and Z homed.
    Machine goes in manual mode. I can jog the machine, I can use the handwheel, I can run programs up until the spindle needs to come on.
    I twist the spindle start button and hit the green spindle enable button and everything dies.
    I am using a rotary phase converter. The machine worked about a year ago. I haven't tried running it because I've been working with other machines. Now I need to get this one up and running.
    Nov 2004
    239
    Re: Bridgeport Interact 2 Series 2
    Update. Got it working. I think it's a power issue. T1 was set to 220 and 20 for the input. My schematic showed input to T1 on 220 and 0. I switched it and was able to start the spindle.
  1. Bridgeport series 1 interact 2
    By matty123 in forum Bridgeport / Hardinge Mills
    Last Post: 11-09-2017, 07:38 PM
  2. Bridgeport series II interact 4
    By skunge in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2013, 07:27 PM
  3. Bridgeport Interact Series 1 Mk2
    By AdeV in forum Bridgeport / Hardinge Mills
    Last Post: 09-03-2012, 11:34 PM
  4. bridgeport series 2 interact 4
    By dcchip in forum Bridgeport / Hardinge Mills
    Last Post: 11-15-2010, 11:47 PM
