Hello, I'm an EZ Trak owner and it may be helpful for owners to share general info.
My BP has been running well since 1996, I have done some great projects on it. I've discovered some interesting things about the old "EZ Crash"! If you have any useful info, please share it here.
To begin with, here is a nice tidbit: Recently I had to replace the bulb behind the green button on the motor control pendant. It is a #949 bulb, 130V, and McMaster-Carr has them, p/n 1505K422, $9.86 each. 949 bulbs are common enough, but Light Bulb Emporium also has a LED replacement version, which should last quite a bit longer: p/n 81190EK (www.lightbulbemporium.com).
Also recently replaced and something that makes my Trak very happy is a new keypad. It is a direct replacement and fixed the aggravating "double-key" syndrome. Older EZ Traks had a slightly different key style, which might make it hard to re-use the colored keys, but somewhere around 1995 they went to this style. Go to MaxGeek or ErgoGeek (through Amazon) and get the Ione Scorpius-32 keyboard - p/n SC32 - $44.95 (Helps to Google it.)
Monitors are another issue. If yours burns out, a flat-screen LCD will work, and it comes up in color. If you want a close fit, try a 9" VGA Monochrome monitor, I got one but don't want to tear into it until my original monitor goes bad. Possibly this one will work: http://www.provantage.com/miracle-bu...7~7MRCL00N.htm
When I first searched for the monitor, EMI said they could do a better-than-original retrofit, but you have to send the pendant back and it's not cheap. Not sure if that still stands. http://www.emi-inc.net/
Links like that are very good to know about. Also see http://www.hardingerepair.com/
