587,220 active members*
2,606 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Explorer I Pneumatic Spindle Brake
Results 1 to 4 of 4
    Feb 2009
    86
    1997 Bridgeport Explorer I equipped with a DX-32 control.
    Alarm message: Spindle Motor Overload
    The Spindle Brake is locked in the "ON" position with the air turned "ON". When the air is turned "OFF" the Spindle Brake is released and the spindle turns freely. The Sheffer Brake Cylinder also moves freely with the air turned "OFF". Any suggestions to solve this problem would be greatly appreciated.
    Regards,
    Bob Adams
    989 798 6581
    Nov 2004
    3028
    Reset the spindle motor overload.
    On the right side of the elec cabinet are 2 contactors for spindle forward/reverse and then the overload. May have a blue or red button.
    George
    Feb 2009
    86
    George:
    Thanks for you response. I will try your suggestion and let you know if that was the solution.
    Many Thanks!
    Bob Adams
    Feb 2009
    86
    George:
    Many thanks for your suggestion. Pressing the blue reset button #96 solved the problem. This site is awesome, thanks to contributors like you.
    Thanks Again and Best Wishes!
    Bob Adams
  1. Bridgeport Series II Interact 4 Spindle Brake
    By UKRobotics in forum Bridgeport / Hardinge Mills
    Last Post: 04-27-2009, 06:22 PM
  2. Bridgeport DX-32 (Explorer I) / Conversion
    By aogonzalez in forum Servo Drives
    Last Post: 01-30-2009, 09:05 AM
  3. Bridgeport spindle brake - how fast should it stop?
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 07-01-2007, 07:11 AM
  4. Bridgeport Explorer CNCs
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 02-11-2005, 01:28 AM
