Hoping someone here has some insight on this. It is a bit of a puzzle.
Background: I have quite a bit of troubleshooting experience but none with the DX-32 control. I am trying to help out a friend with an older machine that was sold and then repossessed so the history is a little lacking. The machine is about 1995 vintage with a 386 based control and Siemens 611 drives.
The problem first seemed to be a drive issue as the Z axis would fault as soon as the drives were enabled so I started down that path. The drive fault indicated a possible wiring problem, but I couldn't find anything wrong and in the process of checking we found that the drive didn't fault if one of the limits were activated. I finally found the wiring diagram and disconnected one of the limits. Then I could jog the X, Y, and Z with no errors through the "jog off limits" function. I thought maybe one of the switches or wiring was shorting to ground dropping out the 24V, but more checking found this wasn't the case. (the limits are a little odd in that there is only one per axis and they are in series) In doing a little more reading, I found the following in the manual: "If any one of the limit switches is open, 24Vdc is removed from the coils of the reversing contactor, turning the spindle motor off." I don't see anything labeled as a "reversing contactor" on the diagram so perhaps this is referring to an older system? In any case the limits go into the AUF board which I don't have documentation on. I am wondering if the spindle drive may be causing the fault or if there is something else that powers up at the same time that could be causing it? Is there any documentation available on the AUF board?
If anyone has any insight or information on the AUF board, I would appreciate it. If I posted it in the wrong forum please let me know which one is more appropriate.
TIA
Jerry
