587,143 active members*
4,602 visitors online*
Results 1 to 12 of 12
    Sep 2004
    209
    Breakout Board
    I decided to make a batch of breakout boards during my mill conversion. The ones I didn't use are for sale.
    More details at: http://www.rammspeed.com/karvemachine
    Chris Kirchen
    May 2005
    173
    What is a breakout board? (I'm not being sarcastic)
    35538
    Quote Originally Posted by Chunky
    A board that usually plugs into the parallel port and usually has connections for stepper drives, home and limit switches, and relays. It makes it easier to wire everything up to the computer.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2005
    339
    hi,
    Your link doesn't work. Is there a mistake?
    Sep 2004
    209
    I changed servers a while ago and the landing page had to change. It's http://www.rammspeed.com/karvemachine/index.htm.
    Chris Kirchen
    Mar 2005
    339
    Are you going to share with us the schematics for those who will prefer to build it by themselves?
    Sep 2004
    209
    Sure. Considering the amount of other peoples knowledge I drew on when I built my machine, I'd be happy to reciprocate.
    I'll post the schematic on my site (www.rammspeed.com/karvemachine/index.htm) sometime during the weekend.
    Chris Kirchen
    Mar 2005
    339
    I have not seen yet your board on your site.
    Dec 2004
    95
    "When a servo is powered up, it jumps"
    Not always. Depends on the servo drive circuit and interface electronics.
    Sep 2004
    209
    The schematic is up: http://www.rammspeed.com/karvemachin..._schematic.pdf
    I couldn't find the file on my computer (must have lost it when I upgraded to XP), so I had to recreate it.
    Sep 2004
    209
    Quote Originally Posted by eldata
    True. I should correct that to read: "On some machines, the servos jump when they are powered up".
    My machine does it. So does a friend's Maho with glass scales--when you power up the drives, the DRO shows the drives correcting themselves.
    But, I've seen others machines since then that don't do it.
    Feb 2005
    39
    sorry to ressurect an old thread, but why have all the lines got pullup resistors on them? are they neccicary and will they work on active low systems as well as active high systems?
    thanks
    Alex.
  1. Parallel Breakout Board
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 03-14-2012, 02:06 AM
  2. PICStep V3.1 and Opto breakout board
    By Garfield2 in forum Open Source Controller Boards
    Last Post: 04-26-2007, 06:04 PM
  3. USB Breakout Board vs. Parallel
    By dwwright in forum Mach Software (ArtSoft software)
    Last Post: 12-09-2005, 08:30 PM
  4. in lieu of a breakout board
    By fly_champ in forum CNC Machine Related Electronics
    Last Post: 03-02-2005, 04:42 AM
  5. Has anyone used Axxus Tech. db1v20 pc breakout board?
    By trubleshtr in forum CNC Machine Related Electronics
    Last Post: 04-09-2004, 12:43 AM
