Just purchased new Haas VF9. Trying to tap m16 x 2 into A36 steel but keeps breaking taps. Suggested speeds and feeds? Parameter settings are okay to my knowledge. Should my cam add a code that switches this machine to metric during the rigid tapping process? I am using mastercam version 9 which does not have metric taps in the tool library. Rigid Tapping 2 inches deep into through holes using Nachi taps after predrilling holes with 14mm drill. Chamfer is .1 by .1 using Trim microsol 585xt coolant in my machine. Actual code given by mastercam
S200 M3
G99 G84 Z-2.0 R.1 F11.11
