587,651 active members*
3,413 visitors online*
Results 1 to 4 of 4
    May 2009
    27
    Angry bp vmc 760/22 tool change problem
    My vmc 760/22 with a dx32 control has been running great until one of my guys e stopped the machine during a tool change. Now, no matter what I do, I get a message that the tools need to be reloaded.
    In addition, when I try to do a tool change, immediately after the z axis jogs up it moves down very fast and gives me an error: "following error limit exceeded" I also get this error if I do a quill up.
    I have tried about everything I can think of to solve this problem.
    the machine homes and jogs. the carousel for the tool holder homes fine.
    Please help.
    May 2009
    27
    anybody out there that can help
    Typically, I post on this site and get some great feedback. Haven't got any responses to this post. My machine is down and I don't know where to turn for support. If anyone can help or if you can give me the name of someone who works on these machines, it would be a life saver.
    tim
    Nov 2004
    3028
    Probably no reply because no one knows what to tell you. A following error means that it cannot keep up with the command of where the control expects the Z axis to be.
    You could turn the feedrate override ON and lower the rapid rate to see what is going on. When moving slower see where it faults. Possible that the BMDCPRMS.sys file is corrupted. The Z axis rapid is slower than the X and Y.
    The motors and drives are Siemens AC type so there are no brushes. The Z also has a brake built in and a special encoder.
    Start there.
    George
    May 2009
    27
    GREAT FEEDBACK
    I slowed the z axis down and it worked fine (albeit really sloooow). Turned the rapid back up and it still works. Thanks so much for your response.
  1. Tool change problem.
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-12-2010, 11:46 AM
  2. TOOL CHANGE PROBLEM
    By Stebedeff in forum Fanuc
    Last Post: 03-18-2009, 02:23 PM
  3. Need Help With Tool Change Problem
    By AZDEN in forum Fanuc
    Last Post: 11-21-2007, 08:44 PM
  4. Problem in Tool change
    By ahmedsamy_81 in forum G-Code Programing
    Last Post: 02-14-2007, 04:02 AM
  5. Problem in tool change
    By ahmedsamy_81 in forum Uncategorised MetalWorking Machines
    Last Post: 11-06-2005, 11:14 PM
