587,404 active members*
3,135 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Bonding V- Across Various Power Supplies
    Aug 2007
    31
    I am building a new controller for a Multicam Router. I am using a Masso G3 Touch for the controller and Clearpath SDSK motors. My question is this,
    Masso tells me to bond the V- terminal for the G3 Touch controller power supply with the V- on any other 24VDC power supplies within the system (I have 2 other 24 VDC power supplies). In addition, I also have 2 Amazon IPC-5 75VDC power supplies for the servos. Do I need to bond ALL of the V- outputs together or just all the 24 VDC V- outputs?
    Attachment 497866
    Dec 2013
    5716
    Re: Bonding V- Across Various Power Supplies
    I normally bond all of the V- wires to panel ground. The exception to this is a non transformer isolated direct rectified line voltage servo power supply, grounding the V- on this would be a dead short. This was somewhat common on old Anilam systems and some others.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2007
    31
    Thanks for your reply.
    I am going to NOT ground the 75VDC V- on the IPC-5 Servo power supplies and see what happens while bonding all the various 24VDC power supplies within the whole system. I will bond all of these via the panel ground.
  1. Power supplies
    By cd_edwards in forum Stepper Motors / Drives
    Last Post: 11-22-2011, 06:38 AM
  2. power supplies.
    By LeeWay in forum Gecko Drives
    Last Post: 05-19-2006, 11:17 AM
  3. Power Supplies Again
    By tintruder in forum Servo Drives
    Last Post: 02-17-2006, 12:21 AM
  4. I need some help on Power Supplies.
    By Tasos_Eco in forum CNC Machine Related Electronics
    Last Post: 02-07-2005, 08:36 PM
  5. Power supplies
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 07-17-2003, 03:41 AM
