587,420 active members*
3,097 visitors online*
IndustryArena Forum > CAD Software > Solidworks > BOM Problem when using multiple sheets
    Jan 2007
    35
    I don't have enough space on a single drawing sheet to show all the components in my G.A. drawing. I have decided to use multiple sheets (2 sheets) to allow me to baloon all the components.
    In doing this, however, I have picked up a problem.... I inserted a BOM on both sheet 1 and 2. When it comes to balooning the components, something goes horribly wrong (particularly in sheet 2). The item numbers in the baloons do not correspond with the item numbers in the BOM???
    Is this a bug in Solidworks 2007, or am I attempting something I shouldn't be or going around it in the wrong way???
    Mar 2005
    21
    multiple sheet BOM
    The balloons of a BOM refer to the active model on each individual sheet. In other words, when you insert a BOM into a sheet, the program will insert the BOM referring to the model that is active on that sheet. If that model is different than the active model on the other sheets, then you will get different balloon numbering.
    In order to get the same numbering sequence, I insert the same model on all sheets, then insert the BOM. I then hide the view (if I don't need it), and place detail views, etc, and insert balloons as needed.
    You can also manually modify the balloon number by changing the number system to 'custom'.
    Hope this helps.
    Regards
    JWI
    Sep 2005
    1660
    Don't forget to right click the view, select properties and down near the bottom left select "link to BOM" and select which BOM to link it to.. this will keep the numbers linked properly also..
    JerryFlyGuy
    The more I know... the more I realize I don't
  1. Looking for feed rates on aluminum sheets
    By eric_bilodeau in forum MetalWork Discussion
    Last Post: 02-04-2006, 03:51 AM
  2. Cnc Machining 1/8 thick steel sheets
    By ccm in forum Uncategorised MetalWorking Machines
    Last Post: 10-28-2004, 08:47 PM
  3. Carbon fiber sheets
    By aghobby in forum DIY CNC Router Table Machines
    Last Post: 04-19-2004, 05:29 AM
  4. Cutting Aluminum Sheets
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 05:12 PM
  5. set-up & operation sheets
    By Bill in forum Community Club House
    Last Post: 08-08-2003, 04:15 PM
