587,449 active members*
2,628 visitors online*
Results 1 to 13 of 13
    Jun 2010
    89
    bobcad tool crib
    I am trying to build a tool crib with all the tools I use frequently. Say 10-20 end mills. The only way I have found to build a tool crib is to make a job that uses that tool, and then save. I'd rather not have to make up jobs that use the 20 end mills just to make the crib. IS there an interface I am missing that allows one to just pick from the master tool list and put those tools into a crib?
    Jun 2008
    1838
    Re: bobcad tool crib
    Brian
    Yes, it is very easy to build a Tool Crib for future use, go to :-
    Milling Tools > right click and select Tool Crib > (New empty Crib will appear) now select a tool type from the list on the left > this will show the tool type already in the Crib > now click Add from Tool Library and select a tool from the Library and click the OK button > selected tool will now be in your Crib > carry on till you have all the tools you want/need in your Tool Crib > now save it out with a name eg "Default Crib".
    Now whenever you start a new job (Do this selection before anything else) you can go to the "Milling Tools > Tool Crib > click Import and select the saved out Tool Crib and you are "good to go".
    If you do it at the beginning of your Job then most of the time BobCAD will/should populate your tool area with what it thinks is the best tool for the particular feature automatically, not often you should need to go selecting tools
    This does of course all depend on whether you have actually set up your tool library properly, it is a bit time consuming as is setting up all your Cutting Conditions and Materials Libraries but if done right these things can save many hours when programming ! ! !
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Jul 2010
    172
    Engine Guy-
    Perhaps you can help me with a similar problem-
    In my Milling Tool Crib--in "Chamfer Tool"--I have a .250X90 degree Sharp Tool.
    When I select -Feature Chamfer Cut--and right click edit--the " Chamfer Mill "
    Selection page opens up (you can only select chamfer mills) I need the " Chamfer
    Mill Tool" page to open up so I can select the above tool which is in the Milling Tool Crib
    under "Chamfer Tool" How can I get this to show up when I choose to edit
    "Feature Chamfer Cut"
    Any help would be appreciated--------Rick
    Jul 2010
    172
    Engine Guy-
    OK-I did what you said--I saved it to a file--Then when I was in Edit
    I chose import and that gave me my choice--But But !! It worked for that
    session but would not save--Next time I opened up the file I had to go through
    the same procedure--- I guess that's the way it is!!
    Thanks for your Help---Rick
    Jun 2008
    1838
    Hi Rick
    Sorry for the delay, been very busy today.
    OK, if you are doing a Milling job and chamfering an edge then you can only use a Chamfer Mill, the Chamfer Tool is only used/available for doing chamfers on holes.
    So, if you have a Chamfer Tool in your shop and want to use it for chamfering Profiles, Pockets etc then you will need to create a Chamfer Mill using the specifications of your Chamfer Tool, that way it will toolpath correctly and simulate correctly.
    Hope that helps
    Regards
    Rob
    Jul 2010
    172
    OK--EngineGuy--
    I guess I can live with that-
    Thanks for the information-----Rick
    Oct 2009
    56
    Re: bobcad tool crib / libary metric tools
    Hi All
    Has anyone set up a standard metric library of tools as opposed to the inch defaults:idea:. I know how to edit them and build a new tool crib
    The more I learn, the more I find there is to learn
    Regards Nick
    Apr 2008
    1577
    If you make one, export it, upload it, and help the rest of you metric weirdos!
    Jun 2008
    1838
    Quote Originally Posted by SBC Cycle View Post
    Ha ha, weirdos eh, be warned there are more of us "metric weirdos" than there are of you "inch dinasours"
    We are the future
    Regards
    Rob
    Aug 2012
    621
    "All I'm trying to find out is the fellow's name on first base" -- Lou Costello
    Oct 2009
    56
    Quote Originally Posted by The Engine Guy View Post
    We are the future
    Regards
    Rob
    Yep even the Brits have seen the light and they invented inches :idea:
    Regards Nick
    Apr 2009
    3376
    We are the future
    Regards
    Rob
    Well,,,Machinist work with decimals.Decimals work on powers of "10".Not so different unless your a Carpenter and bring out the tape measure.
    Oct 2009
    56
    Re: bobcad tool library ERROR
    Found this when using metric system library bobcad for 5/16 Ball endmill and yes I do have imperial tooling as well but it was brought cheap as it was marked 8mm undersize
    Regards Nick
  1. Adding to tool crib from lib
    By bb218 in forum BobCad-Cam
    Last Post: 01-02-2013, 02:21 AM
  2. Tool crib question
    By Joesph Jackman in forum CamWorks
    Last Post: 12-22-2011, 02:41 PM
  3. Functional CNC Tool Crib
    By jheal in forum CNC Tooling
    Last Post: 03-04-2011, 07:25 PM
  4. Tool Crib
    By Billet Sean in forum MetalWork Discussion
    Last Post: 11-10-2009, 04:12 AM
  5. Tool Crib Software?
    By cad01 in forum Want To Buy...Need help!
    Last Post: 06-29-2009, 07:08 AM
