Has anyone tried to run a Gerber Sabre 404 router with Bobcad-cam? I have a full sheet specifying the relatively few G-codes it will accept (seems they crippled the machine so that it will only run 2.5 axis for G-code). However, I know that the machine is fully capable of 3D. I know this because Gerber has an "Autocarve" feature that will cause ramping for square corners - a 3D move. Also, Cimigraphi worked on the machine in full 3D by using Delcam's "Gerber spooler" (I can't find the HASP to run Cimigraphi anymore, though).
How do I interface Bobcad with the machine for full 3D use? Sure, Bobcad's tech department says they will come up with a post processor to run the machine, but I have a feeling they will only do G-code, which will only run the machine 2.5 axis.
My idea is that, if nothing else, maybe Bobcad's post can be configured to feed Delcam's Gerber Spooler, although the code is odd to say the least. Anyone have any ideas?
I can provide samples of the code generated by Cimigraphi's post processor to feed the spooler, as well as the script used to run their post processor.
Thanks,
-John
:withstupi
