587,402 active members*
3,026 visitors online*
Results 1 to 2 of 2
    Aug 2014
    18
    Board controller
    Mar 2007
    2083
    Re: Board controller
    Hi
    since both kits use the same 24V supply
    out of the 2 kits -
    the CNC kit Nema23 stepper motor 3axis (23HS6430 +DM542)+350W24V+breakout board
    is the kit I'd choose
    1st the stepper motors have a lower inductance and should run faster
    2nd if you damage a stepper driver the DM542 driver is easier to replace than the IC's on the all in one board
    the TB6560 Control Board has a habbit of self destructing
    see
    http://www.cnczone.com/forums/genera...r-updated.html
    John
  1. Looking for controller board for PRECIX
    By mtrobregado in forum Commercial CNC Wood Routers
    Last Post: 05-20-2015, 02:38 AM
  2. Which controller board/drivers to go with?
    By AmbiguosMind in forum Controller & Computer Solutions
    Last Post: 01-24-2012, 05:30 AM
  3. CNC Controller board
    By alansmith in forum Commercial CNC Wood Routers
    Last Post: 08-31-2009, 12:28 AM
  4. SM-1 controller board ID
    By tjs88yj in forum HURCO
    Last Post: 03-30-2008, 07:18 AM
  5. One controller board does it all?
    By Hack in forum CNC Machine Related Electronics
    Last Post: 03-07-2006, 10:51 AM
