Having some surface finish issues which I think are related to low tool clamping force. I've ordered 100 new belleville washers to replace the old stack. I see from the parts breakdown how they are to be installed. The parts diagram doesn't show how to take it apart, of course, though it looks pretty straightforward.
Anyone have one of these apart to replace the bellevilles? Any tips or gotchas?
Looks like I can remove the spindle cartridge from the casting, then remove some kind of a nut from the top where the knockout cylinder presses onto the drwabar. Presumably the whole drawbar then sides out of the spindle taper.
I'll measure the knockout cyl to drawbar clearance before I take it apart so I can put it back the same way.
Aaron
