587,496 active members*
3,285 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > BMC-20 w/Max II drip feed......
Results 1 to 7 of 7
    Sep 2007
    371
    In my machine BMC-20 with Ultimax II, wich we just started to use, we are able to comunicate g coded programs from the PC and to the PC with no problem as far as they are smaller than 1000 lines or so due to the memory size. The question is: Is this control capable to drip feed a program?? I can not find anything in the manuals.
    Thank you all...
    GP.
    May 2007
    64
    GPena
    The machine is already set up to drip feed, it just does it you do not have to set anything in the control just set up your dnc software to do it and it will do it. If you can up load and down load you should be ready to go. When you donwload a large program to the control it will down load and stop when the buffer is full as soon as you start running code the machine control will delete the code that was just run and down load the next code
    Rick
    Sep 2007
    371
    Rick:
    As per your comments, it stops when the buffer is full; it shows 9% memory. Then we press "AUTO", then "RUN PROG" softkey, and "START" button. It runs the program but it stops on line 1524, this means that it doesn't load the rest of theprogram. Our cable confirguration is:
    ROUND CONNECTOR DB-25 IN PC
    A---------------------1
    B---------------------2
    C---------------------3
    D---------------------4
    E---------------------5
    F---------------------7
    G NOT USED
    H NOT USED
    Could it be the cable???
    Thak you for your help.
    GP.
    May 2007
    64
    Gpena
    I think it is your cable
    I will check on the cable tonight, as I do not have the info at hand as I am at work and the info is at home.
    As far as I can remember only three pins are used and a couple are jumpered.
    Rick
    Sep 2007
    371
    Rick:
    Great, I'll wait for your reply.
    Thank you.
    GP.
    May 2007
    64
    Gpena
    Here is the cable info, your cable looks ok be sure to set the PC dnc software to "software handshaking"
    Hurco round connector 25 pin serial
    pin B recieve data ----------pin 2 transmit data
    pin C transmit data----------pin 3 recieve data
    pin F signal ground----------pin 7 signal ground
    Hurco round connector 9 pin serial
    pin B recieve data ----------pin 3 transmit data
    pin C transmit data----------pin 2 recieve data
    pin F signal ground----------pin 5 signal ground
    Set dnc for SOFTWARE handshaking
    good luck
    Rick
    Sep 2007
    371
    Rick:
    We will test...thank you very much.
    GP.
  1. Inexpensive DNC for Drip Feed
    By Tazzer in forum DNC Problems and Solutions
    Last Post: 01-28-2008, 12:27 PM
  2. Drip Feed - DNC - Fanuc 16i
    By gm3211 in forum DNC Problems and Solutions
    Last Post: 09-21-2007, 08:43 PM
  3. Drip Feed Boss 6
    By TPMX in forum Bridgeport / Hardinge Mills
    Last Post: 06-15-2007, 04:01 AM
  4. Drip feed Boss9
    By pcsimp in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2006, 01:38 PM
  5. Drip Feed
    By camtd in forum Surfcam
    Last Post: 08-01-2006, 12:09 AM
