587,905 active members*
3,199 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Biesse rover 316 controller ID question
Results 1 to 14 of 14
    Dec 2010
    0
    First time CNC purchaser trying to learn my machine. I have just received my pdf Users Manual file from Biesse for the machine. However they asked me what type off controller I have. Unfortunatley I cannot find any indication of what controller it is. Is there an obvious way of determining this? One other thing is the manual called for a voltage input of around 380 volts but the machine and contoller say 600 volts. Were there two different versions for this machine? The manual pictures otherwise look identical.
    Any help is appreciated.
    Jun 2010
    51
    Hi, controller should be RT480 or RT481 look at monitor top right corner. Or at screen when machine starting.
    Dec 2010
    0
    Thanks for the response, Biesse sent me a quote for software compatibile with either controller. I am sure at $5,000 however there are far better options for much less in the after market. Hoping so anyway.
    Oct 2007
    269
    As for the required voltage, look at one of the control transformers. The previously hooked up input voltage is set up on them. Input voltage is usually varied, but the machines required voltage, is one voltage.
    Jim
    Jun 2010
    51
    So your Rover 316 without software now?
    Dec 2010
    0
    The router came with no disks and I am not sure what kind of programing is inside hard drive. Biesse said the machines don't come with any desk top software just whats inside machine and I really don't want to learn g-code. Seems like there are several companies now offering more user friendly software for these machines.
    I bought it at auction for cheap ($1,000) so this is a shot in the dark but the price was worth the gamble. It received new parts in 2008 and is complete so I hope I do O.K. I tracked down the last owner through Biesse and they said it needs a new card. I have contacted the service person who's name was inside the panel door to see what more I need to do. Trying also to locate a 600V transformer and phase converter.
    Aug 2010
    0
    i started my rover 336 without any informations so if you need help email me.
    maybe my cnc is similar with yours.
    Jun 2010
    51
    Biesse Rover 316 software
    Maybe someone have Biesse Rover 316 software backup? Because i still cant run my Rover, hardware i repaired all tested and should work. Now i think that i cant run it because of software. Software not full and controller cant find one plate. That plate tested and should work. So maybe someone can help with software?
    Nov 2005
    172
    The R316 typically came with the SY3 or SY4 control, this was the control before the NC481 and RT480. It is a relatively simple control to learn.
    Mark T.
    CNC Custom Services - CNC Service, CNC Support, CNC Training for the CNC Woodworking Industry focused on CNC Routers and CNC Point-to-Point Machines.
    Jun 2010
    51
    thank you for answer. first of all i need to repair that machine, because i still can't run it. maybe it is not difficult to learn. i do not know for sure if it is problem with software, because i have original back up files. now we thinking that problem with FIOZ plate. so now we looking where we can order that plate.
    Quote Originally Posted by MarkT View Post
    Mark T.
    Nov 2009
    121
    Re: Biesse rover 316 controller ID question
    ok i have information regards
    Service SCM BR Guest
    Hi, use the Mastercam or TopSolid for the make programs post processator for the Rover.
    Via iPhone of the Tapatalk
    Feb 2017
    1
    Hi we need instruction manual for BIESSE ROVER 316 S with RT480 controller
    English version
    anyone, please
    Nov 2009
    121
    yes
    [email protected]
    [email protected]
    Quote Originally Posted by marsi986 View Post
    English version
    anyone, please
  1. Biesse Rover 322 whith nc481 controller
    By stoned in forum CNC Machining Centers
    Last Post: 03-09-2013, 11:38 AM
  2. BIESSE ROVER 346
    By Bob at MFD in forum Biesse
    Last Post: 03-29-2011, 11:29 PM
  3. need help rover biesse 24
    By neon_x in forum CNC Machining Centers
    Last Post: 12-05-2009, 08:22 PM
  4. Controller for Biesse Rover 321R
    By grc in forum Commercial CNC Wood Routers
    Last Post: 07-31-2009, 12:11 PM
  5. Sign Writing on a Biesse Rover 22 NC400 Controller
    By Midnight Mayhem in forum CNC Machining Centers
    Last Post: 02-07-2009, 07:15 AM
