587,591 active members*
4,107 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Best Cut Operation?
Results 1 to 5 of 5
    Feb 2012
    40
    Best Cut Operation?
    Hi all,
    I'm just wondering what would be the best way to cut something like this(attached).
    I've been using Contour(3D) in these kind of ops, but looks like there's no control over where
    the tool enters: I need the tool to go in where there's no material of course.
    I have had a few bad experiences where I damaged the part
    Any input would be a great help to me.
    Thanks,
    Attached is in Mastercam Mill X5.
    Attached Files Attached Files
    Aug 2012
    63
    Re: Best Cut Operation?
    Move the start point of the chain geometry. Click geometry, right click on chain, click on start point and put it where you want it.
    Feb 2012
    40
    I never knew that, thank you!
    Feb 2012
    40
    This leads me to ask you another question: How would you control the start point in operations like Surface Finish Constant Scallop?
    I tried your method and it didn't work out...I've been trying to use the Use Approximate Start Point option...but it is not even close.
    So is there any other way I can try? Thanks a lot!
    Aug 2012
    63
    Approximate start point works best if the point is on the surface itself. Or at least on a containment boundary that lies on the surface. It needs to be really close to where you want to start. Sometimes I use 2d containment that is above the surface and a point on that doesn't always make it start where I would expect it to. try using dynamic point to place a point on the surface and see if that helps you out.
  1. Spindle operation
    By Bob Hallinan in forum Chinese Machines
    Last Post: 12-22-2012, 10:10 PM
  2. spindles and operation
    By cabnet636 in forum Camaster
    Last Post: 11-07-2008, 01:59 PM
  3. Facing operation
    By mikeh78 in forum BobCad-Cam
    Last Post: 07-14-2008, 11:08 PM
  4. operation
    By camtd in forum FeatureCAM CAD/CAM
    Last Post: 11-28-2007, 05:07 PM
  5. 102 Mis Operation
    By mattme in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-03-2007, 05:48 PM
