I am considering building my first machine. In the beginning it's going to be a simple 3-axis machine with a router for the spindle, but I also plan to eventually add a A/B axis with a Dremel-clone style tool for the spindle to do fine detail work in wax for jewelry casting.
My question is this: on a 5-axis machine, you have a bearing that rotates on a plane parallel to the table. I normally know this as a lazy susan bearing, but I know that's not the correct name for the mechanical part. What do you call this bearing? Is it a thrust bearing?
