587,383 active members*
3,270 visitors online*
Results 1 to 1 of 1
    May 2007
    3
    Bearing Loads
    I am designing a carriage assembly that guides a cable through a set of rollers. The carriage is driven by an acme leadscrew and is supported by two round rods. The carriage has a set of flanged plastic bearings for each rod. I am having a hard time with the free body diagram of the carriage. I am trying to determine both the axial load on the acme nut (so I can determine the amount of torque required to move the carriage) and the loads on the bearings so I can estimate the frictional forces I must overcome and ensure I have a suitable bearing material and bearing size. I don’t need too detailed of an analysis, just something quick and dirty to ensure I’m in the right ballpark. I would like to simplify the diagram by assuming point loads at each of the bearings. However, I’m not too sure where I should place the point loads or where contact should be assumed to be made or not to be made. I would like to assume the worst case and design for that. I have attached a sketch of what I am working on. Any suggestions would be greatly appreciated.
    Attached Files Attached Files
  1. LOADS of problems, hope you can help
    By djlee in forum Commercial CNC Wood Routers
    Last Post: 02-10-2010, 07:23 PM
  2. thk rails and loads from different directions
    By endgrainguy in forum Linear and Rotary Motion
    Last Post: 03-13-2008, 01:06 AM
  3. What side loads should wedesign to?
    By pvogtcharlotte in forum MetalWork Discussion
    Last Post: 02-23-2006, 07:15 AM
  4. MIC-6 jig plate allowable loads?
    By walter in forum Mechanical Calculations/Engineering Design
    Last Post: 10-24-2005, 10:18 PM
  5. CNC router deflection calcs and cutting loads?
    By Linus in forum DIY CNC Router Table Machines
    Last Post: 09-10-2004, 04:08 PM
