587,935 active members*
4,295 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Ballscrew not served by oiler: how to lube ???
    Mar 2009
    163
    After much checking of the plumbing, it seems the Z ballscrew of my nm135 is not serviced by an oiler line.
    Odd, because all 6 millways and the X and Y ballscrews all have oil lines.
    Anyhoo... I guess I never noticed the Z ballscrew non-oiling because often I manually oil in liberal quantities. But now that the machine is in its full enclosure, it is difficult to access the Z ballscrew.
    So.... what kind of lube should I use on the Z ballscrew? Grease? Oil? Ideally it would be a lube that can last, say, 50 hours of operation before needing re-lube.
    Dec 2003
    24220
    Usually something like Vactra2, Waylube.
    Al.
    Albert E.
    Dec 2006
    222
    I like Vactra a lot - it's just tacky enough to stick while not so sticky as to glue on swarf. Pretty nice all around.
  1. Ballscrew grease/lube/oil? Yeah, seriously.
    By cnczoner in forum Linear and Rotary Motion
    Last Post: 12-16-2021, 01:35 PM
  2. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  3. NM135 Oiler on Z ballscrew??
    By Frogblender in forum Novakon
    Last Post: 10-12-2011, 04:39 PM
  4. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
  5. Changing lube on a ballscrew
    By Guldberg in forum Linear and Rotary Motion
    Last Post: 06-19-2009, 02:55 PM
