587,547 active members*
3,043 visitors online*
Results 1 to 7 of 7
    Dec 2005
    504
    Backlash compensation parameter?
    I just rebuilt my Y-axis with a new shaft, bearings, and pinion gear. My Y-axis backlash is now minimal and my circles are round again. Because the backlash was so bad previously I want to clear any stored backlash compensation values and re-calibrate. I've look through my parameter list but I'm just not finding it. Does Multicam support backlash compensation? If so, where is it set?
    Dec 2005
    504
    Re: Backlash compensation parameter?
    I reached out to my local vendor this morning. This is the answer. Now I need to figure out how to tune the accel/decel.
    There is no backlash compensation, all we can do is adjust accel/decel
    Those are params 502/xaxis and 512/yaxis
    Dec 2013
    5716
    The real question is: Does it need to be adjusted? Is the machine running OK? If so, I would say nothing needs to be done.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2005
    504
    The machine is running fine. The pinion was rotating on the shaft due to roll pin wear. After remaking the shaft and replacing the pinion the backlash is limited to the minimum required. I haven't put a lot of time on the machine since I swapped out the parts yesterday. I did about 120 16mm holes today. They definitely looked a LOT more round but in gauging them there is some variation.
    Jul 2018
    6483
    Hi all- A general question about backlash compensation in the controller. Does it compensate along the whole path? or does it just apply it at ends of paths? Peter
    Dec 2005
    504
    Quote Originally Posted by peteeng View Post
    It compensates for the backlash on the change of direction by adding the backlash amount. It's normally set as a parameter on the machine tool. I'm a bit surprised Multicam doesn't support the feature. It's possible they handle it some other way.
    Because my backlash was so high, I really just wanted to make sure nobody had set crazy values previously.
    Now that I have the mechanical backlash under control I can begin exploring my options. It's possible some of my variation today was a result of the material.
    Jun 2010
    463
    There isn't any compensation for backlash because you can only turn out so much, eventually there is no number you could put in the controller to comp out.
    On a Multicam machine you more then likely still have a mechanical issue in either:
    Gear box
    Drive Gear
    If my be as simple as you aren't engaged completely into the rack...or the rack needs replacement
  1. Backlash Compensation and more...?
    By cordvision in forum Tormach PathPilot™
    Last Post: 02-23-2016, 02:37 AM
  2. BackLash Compensation
    By bearracecars in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-21-2009, 04:36 AM
  3. Backlash Compensation
    By solek in forum Benchtop Machines
    Last Post: 03-05-2008, 08:22 AM
  4. Backlash Compensation
    By utengineer04 in forum MetalWork Discussion
    Last Post: 04-26-2005, 05:42 PM
