587,672 active members*
3,166 visitors online*
Thread: Backlash
    May 2009
    327
    Backlash
    I have an issue with my y axis that I am waiting on parts for that is causing excessive backlash. I have a huge order that I have to get some parts cut for that are not tight tollerances. Can I just use the backlash compensation in Mach? Anything I have to look out for?
    Thanks - Keith
    Jun 2005
    1730
    Re: Backlash
    Keith,
    Wait for the parts, backlash compensation sounds great but in reality it kind of works, but fixing the cause for backlash is the right solution. Especially if you have a large order, you don't want that stuff all screwed up.
    Russ
    Jun 2014
    1780
    Re: Backlash
    Quote Originally Posted by CNCMAN172 View Post
    Keith,
    Russ
    I think it "kind of works" in Pathpilot as well, I cut some hexagonal parts with backlash set and it didnt seem to help, the flats when measured still are off by a thou or two. It does work when probing, maybe because the moves are in the X or Y directions only (no diagonals).
    mike sr
  1. Spiral anti-backlash couplers introducing backlash!
    By MArruda in forum DIY CNC Router Table Machines
    Last Post: 06-07-2011, 08:31 AM
  2. help with Backlash
    By native34 in forum Benchtop Machines
    Last Post: 04-22-2009, 04:18 PM
  3. Backlash Compensation / Backlash
    By dwessels in forum Benchtop Machines
    Last Post: 02-23-2009, 05:27 PM
  4. Replies: 8
    Last Post: 03-10-2008, 09:35 PM
  5. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 08:35 PM
