Open the post in he editor. Go all the way to the bottom. You'll find some numbered questions. One of these has to do with the Rapid Rate for the machine. It helps if this is set close to your machines rapid, not exact. The Backplot does not account for acceleration/deceleration. so if your machine does 800 IPM rapid set it to 650-700.
It's also a good idea to start with a cycle time you know and wirk backwards. Keep changing the Rapid Rate until it's close to the known cycle time.
But Vicros is right. You'll never get it perfect, 100% accurate.
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
