587,753 active members*
2,977 visitors online*
Results 1 to 5 of 5
    Nov 2007
    79
    B axis for horizontal mill OM
    hi
    i have a horizontal milling machine FANUC controller OM with rotary table
    the table is B axis but the G code 107 for cylendrical interpolation is not working, because it's optional and the manufacturer disable it from the controller.
    the table is rotating just to a certain angle as the operator specifys in the program, i mean the table is not continously rotating to make a cylendrical interpolation operation ,
    so i am thinking if there are any way to adjust the table movement, maybe change some parameters or do some mechanical adjustments or both.
    the point is i want the G CODE 107 WORKING.
    note: when i write a G107 in a program, alarm occurs says G code not supported
    are there any way to make G107 works ?
    thank you,
    Dec 2006
    34
    The machine probably doesn't have the option.It is called a "full 4th axis"'what you have is a 1 degree 4th axis.Can you rotate the table with the pulse generator or do you have to use mdi?
    Nov 2007
    79
    Question
    Quote Originally Posted by rharter52 View Post
    i can rotate the table with MDI or in program, i didn't understand what you mean to rotate the table with the pulse generator ???
    thnx
    Dec 2006
    34
    pulse generators and handle are the same thing.I have 3 horizontals,one is a mori-seiki sh-50 with a fanuc 18.It has a 1 degree table and cannot be rotated with the handle.I also have 2 matsuura hplus 300 with fanuc 30i control.they have a full 4th axis,i can rotate the table by using the handle.that is a simple way of checking to see if you have a full 4th axis.I would never buy another machine without that option.believe me it is worth the 20 or 30 thousand dollars extra.
    Jan 2013
    9
    Re: B axis for horizontal mill OM
    Hi my name is Zoran i need post for B axis for horizontal mill OM. Do you giv me you post pls . I have problem, in work. Tnx
  1. How to drill and face mill using table type horizontal boring mill
    By SatishNaik in forum News Announcements
    Last Post: 10-09-2013, 01:10 PM
  2. Z-axis resolver issue on Cincinnati Milacron Horizontal Mill
    By patty sanders in forum Cincinnati CNC
    Last Post: 01-06-2011, 03:52 PM
  3. $400-Master Horizontal MILL 3 axis BIG.
    By diyengineer in forum Want To Buy...Need help!
    Last Post: 09-10-2010, 11:45 PM
  4. HS1 horizontal mill with auxillary axis alarm
    By teal854t in forum Haas Mills
    Last Post: 04-18-2009, 06:47 PM
  5. Disabling A-axis, horizontal mill
    Last Post: 03-24-2009, 12:56 AM
