586,530 active members*
2,732 visitors online*
IndustryArena Forum: Aspire
Page 3 of 9 12345
Threads 41 to 60 of 165
Discuss Aspire software here!
  1. Woodburning pen advice needed
    Started by yafimski, 01-18-2019 08:53 PM
    burning, pen, tip, woodburning pen, z height
    01-18-2019, 08:53 PM Go to last post
  2. 3D milling 8mm bit issue
    Started by yafimski, 12-29-2018 08:35 PM
    4mm, 8mm, bit, pass, wood
    01-13-2019, 08:32 PM Go to last post
  3. Exclamation Cutting out stencils in Aluminium
    Started by soydemadrid, 12-05-2018 03:14 PM
    cnc, metal, spindle, tips, work
    01-06-2019, 05:37 AM Go to last post
    01-06-2019, 02:56 AM Go to last post
  4. Newbie needs help with aspire...
    Started by Kristjan1505, 10-24-2018 10:17 AM
    01-04-2019, 09:48 PM Go to last post
  5. Vectric Aspire V3 post processor menu
    Started by cncstudies, 12-24-2018 09:57 AM
    01-04-2019, 02:11 PM Go to last post
    12-27-2018, 06:59 PM Go to last post
  6. 1mm bit broke off at start of mill
    Started by yafimski, 12-21-2018 06:55 PM
    1mm, bit, broke, reason, settings
    12-25-2018, 12:52 PM Go to last post
    12-21-2018, 01:52 PM Go to last post
  7. Open vectors??????
    Started by Andyshomecrafts, 09-08-2017 08:31 PM
    greyed, join, open, tab, vectors
    11-25-2018, 12:17 AM Go to last post
  8. Z zero at top or bottom of work piece??
    Started by dalob, 06-16-2018 11:35 PM
    bottom, cnc, piece, top, work
    11-25-2018, 12:13 AM Go to last post
  9. Aspire vs Meshcam?
    Started by Moose842, 07-16-2018 12:49 AM
    aspire, cnc, file, mesh, meshcam
    11-25-2018, 12:09 AM Go to last post
  10. V-Carve to Aspire Upgrade thought
    Started by Gary-Wiant, 11-21-2018 09:46 PM
    aspire, photo, upgrade, v-carve, v-carves
    11-25-2018, 12:03 AM Go to last post
    10-22-2018, 04:38 PM Go to last post
  11. Custom Depth with Vector Boundary Tool
    Started by tree32, 10-02-2018 11:08 PM
    artcam, aspire, create, tool, vector
    10-02-2018, 11:08 PM Go to last post
  12. Crv3d file
    Started by Ivan_milanja, 06-12-2018 06:18 PM
    computer, crv3d, file, i’ve, open
    06-20-2018, 01:32 AM Go to last post
  13. Aspire/Xilog 3D models machine slow
    Started by AMCI, 05-16-2018 01:51 AM
    3-d, aspire. vectric, cnc, plunge, scm
    05-16-2018, 05:11 PM Go to last post
  14. V-Carve flat depth problem
    Started by darkclown, 04-04-2018 04:42 AM
    04-04-2018, 04:42 AM Go to last post
  15. Choosing between programs
    Started by toaren01, 02-12-2018 06:53 PM
    aspire, cost, high, mastercam, students
    02-12-2018, 08:11 PM Go to last post
  16. stripes not completing
    Started by forbri40, 01-30-2018 09:35 PM
    axis, cut, stripe, stripes, times
    02-05-2018, 09:40 PM Go to last post
Page 3 of 9 12345
Forum Information and Options
Users Browsing this Forum
Thread Display Options
Order threads in...
Icon Legend
Contains unread posts
Contains no unread posts
Hot thread with unread posts
Closed Thread
Thread is closed
