587,421 active members*
3,204 visitors online*
Results 1 to 7 of 7
    Jun 2010
    98
    Arrow Artcam/Mach3 Problem
    Here is the problem. I made up a file to cut in Mach3 in Artcam. I used the post in Artcam to create a toolpath file with the gcode the Mach3 can use. When I go to cut it in mach3 it automatically changes my axis ratios. Instead of having 1 inch = 1 inch, 1 inch of movement = like .01 inches or so on the digital DRO. This take the image from about 40mmx40mm and blows it up huge. I am trying to cut it on a sherline mill so it only has about 4x8 inches of travel.
    Any ideas why a gcode file can or would change the actual traveled distance????
    Please help. I can't cut anything yet THanks
    Nov 2003
    244
    did you setup artcam to use inch scale?
    ...He who makes no mistakes makes nothing! ...
    Tom
    Jun 2010
    98
    Quote Originally Posted by tpworks View Post
    Probably not. How do I do that? Thanks
    Nov 2003
    244
    when you create a new file you have that option.
    Tom
    Nov 2010
    0
    Sounds like your post processor has some different settings in it than what it needs. I used to install Biesse machines and a few times you would see things like that from third party softwares. Usually someone in the support team where you bought the software can take a look at the g code and post and decipher out what is missing or start over to tie the two languages. or it could be that like TP says your scaling could be off in the post or between the two softwares. I would call artcam if you can and get a new post.
    Jun 2009
    13
    In Mach3 need to set motor tuning for 3 axis. This process very important .
    Program need to know pit of lead/ball screw and your motor. and In Artcam program post process important to. I found same your problem now my CNC.work complete, and scale OK. sorry for my English I'm from Thailand.for more information about calculate Mini CNC Calculation :cheers:
    Jun 2010
    0
    Hi all,
    if you use mach3 - in Settings, above reset button is one button "Set steps per unit"
    you press it - it asks for an axis - then asks for a value to move machine on that axis - after move it asks for real move distance (you need to measure it) and then asks you to accept new value for steps per unit.
    You will find that value in Config / Motor tunning / on each axis where you can change it manualy.
    Hope it helps.
    regards,
  1. MACH3 Post Processor for ArtCAM
    By TomL21 in forum Screen Layouts, Post Processors & Misc
    Last Post: 12-31-2011, 02:56 AM
  2. 3DReliefs.com 3D Reliefs artcam g code shopbot mechmate mach3 cnc
    By jasonmbeamer in forum News Announcements
    Last Post: 11-10-2010, 05:32 PM
  3. ArtCam Pro and Mach3
    By AngelT in forum ArtCam Pro
    Last Post: 08-19-2008, 04:56 PM
  4. Artcam Feature problem
    By djh82uk in forum ArtCam Pro
    Last Post: 01-16-2008, 11:19 PM
  5. ArtCAM & Mach3 for Plasma and Oxy
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 05-31-2006, 07:01 PM
