587,215 active members*
3,275 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Argh! Was I ripped off? Please Help Me!
Page 1 of 2 12
Results 1 to 20 of 22
    Jun 2005
    73
    Got this Spectralight 0200 set up on e-bay... thought this would be fun for my first CNC to start learning with and making some small stuff from aluminum and wax and such.
    Now the guy I bought this from swore up and down that you didn't need a proprietary card from Spectralight to control this thing. That it could be controlled through the printer port alone. So where does this thing go?!?
    And if what he says is right, where should I get the software for controlling this through the printer port connection (which there is one to the controller). And another thing, if you can control this thing through the printer port alone, why would spectralight go to the expense of another cable?!? This is my first CNC so if someone could hold my hand with this until I get it up and running, I'd really appreciate it!
    Thanks!
    Mar 2004
    847
    That looks like a DB9 serial connector to me.
    Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
    Mar 2005
    57
    0200 specifications link
    Uh oh, this page mentions PCI adapter card
    I wonder if your seller ever even used this machine ???
    Jun 2005
    73
    Quote Originally Posted by JavaDog
    Yes, but it would need a gender changer to just plug right into a serial port... another kinda concerning thing is that on the cable it is labeled "connect to 9-pin connector on LMC interface card in computer"
    I'm loading the trial version of Mach 2 on the laptop as I type... maybe I'll figure out how to make it work without plugging this into anything, but I'm kinda skeptical at this point...
    Dec 2003
    24223
    It appears to me also, to need some PCI/ISA card and it runs their proprietary CNC software.
    Your best bet would be to contact Spectralite
    Al.
    Albert E.
    Feb 2005
    750
    The guy is absolutely right. It will run regular cnc software through the printer port, as soon as you make a boat anchor out of that black box and go buy a new control system.
    Laugh about it. Yes you were given incorrect information, but I doubt you got "ripped off". Theyre nice Sherline CNC mills with decent motors, and from what I understand you can buy an upgrade from them that will allow you to use it more conventionally, but I think its cheaper to use the power supply and the case and put a Zylotec or HobbyCNC board in it. With a little re wiring you'l have a GREAT machine to start out with. So its not all bad. At least its not some piece of garbage that you cant do anything with. Contact Spectra Light (Light Machines?) and see what they say, then check out Zylotec and HobbyCNC. Good Luck, and dont worry, you didnt do to bad. With less than a hundred bucks (HobbyCNC board) and a weekend or couple evenings you can have that thing running fine.
    Halfnutz
    Apr 2003
    470
    I'd look in the controller. The controller might be able to be separated (Or is already separate) from the motor drives and with a Parallel port Breakout board you might be able to send Step/Dir signals to the existing drives. You might need to be a bit more electronically inclined than Average Joe perhaps.
    Nathan
    Aug 2004
    2849
    Well firstly if the motors are just motors without a driver, then you'll need a driver for each motor. What's in the controller....is it just a single board PC?
    Jun 2005
    73
    Quote Originally Posted by anoel
    I'll pop the hood tonight and find out what's in there. I was starting to investigate just buying a HobbyCNC kit per Halfnutz suggestion.
    As for electronically inclined, hmm... I do OWN a soldering iron, and I passed a few basic electrical classes in college, but I'm prolly gonna need some hand holding to do anything I can't look up explicitly on a schematic now! I'll post pics here tonight.
    Thanks for the help all!
    Mar 2004
    1306
    You#ll do fine. The mechanical part is the hardest and most work. At the worst case if you have to toss the drivers, a three axis Xylotex is not that expensive, and then you can use TurboCNC, which is free, or $60 once you decide you like it and want to do the right thing and support the authors.
    Regards,
    Mark
    Jun 2003
    1365
    It is a ISA/PCI card to plug it in, you might want to take a look at the drive system and see if you can get it to run off step and direction. I heard the cards for those machines are pretty outrageous to buy.
    Jon
    Jun 2005
    73
    Popped the hood:
    Checked the power supply with my handy-dandy multimeter- it's making 42.8VDC
    Looks like one big ol' board. not modular. So what can I salvage, and where do we go from here?
    As mentioned, I can follow a schematic and I can solder stuff if instructions are clear. Maybe I'll build a controller and put it in this box... For my purposes, I need to go inexpensive, and don't need a lot of frills. I just want a basic 3-axis controller that's easy to work with.
    Thanks so much!
    Mar 2004
    1306
    What is the voltage / amperage of the motors? That will determine whether you can do the job with a three axis Xylotex, or whether you need to go up to Geckos.
    Regards,
    Mark
    Jun 2005
    73
    All I know about the servos is what is on the spec sheet:
    "• Feed rate: 2-300 mm/min (0.1-12 ipm)
    • Rapid traverse: 762 mm/min (30 ipm)
    • Stepper motors: 70 Ncm (100 oz. in.), 200 step/rev"
    there are really no markings on the outside of the motors. I sure hope it'll work with the Xylotex, since I really can't afford to shell out for Geckos at this point.
    Mar 2004
    1306
    Are the steppers four, six, or eight wire?
    Measure the resistance across a phase.
    These are pretty wimpy motors, I kind of doubt you will need anything more than a Xylotex.
    Regards,
    Mark
    Jun 2005
    1
    Hi everyone
    Need 34nema bipolar steppers for a good price anyone any could recomend
    thanks
    Henry
    [email protected]
    Jun 2005
    73
    they are 8-wire. Only 4 wires connected, only resistance number I can get between the pins is 3ohm. does this seem right?
    Jul 2003
    114
    I just saw this thread and it looks to me like you will have to either modify the power supply or replace it. 42 volts is too much (35v max) for the xylotex. A 24 or 28v ps is recommended.
    Feb 2005
    750
    Try to find 35V or less somewhere, preferably close to the bridge rectifier output, or from the pos side of one of the larger capacitors and the comm. or ground. The Hobby CNC board (kit) will handle up to 35V input and is only 79.00 It's a great kit, easy to put together and work with and is very similar to the Zylotec, it's based on the same driver chip set.
    Halfnutz
    Jun 2005
    73
    Sorry, time for an update,
    I did end up going for the Xylotex boardw/ 24VDC power supply for the bi-polar motor control. I'm using TurboCNC for software as it's low overhead, and well, DOS is boss. It's up and running and I've made my first text engraving to try it out, and thought it would be nice to start making some of those cool looking wood cuttings of photographs I've seen on here.... downloaded MeshCAM trial, and had some issues... mostly my g-code file was like 7 Megs and after running for about 18 hours, I decided the wood cutting wasn't going to be worth it... Anyway that's material for another post...
    Short story is, Xylotex + TurboCNC and the old Spectralight is running like a champ. Sure couldn't have done it without the help I got here, Thanks 10^9!
Page 1 of 2 12
