I hacked up a post for HSMexpress on the pcnc1100 a couple of years ago, when HSMexpress first came out, based on the first two public posts I could find, which both had bugs. I wrote up some custom subroutines in javascript that generate tapping cycles for two different types of tormach tapping heads that I have (tension-compression and reversing) and it seemed to work fairly well, but I never had a chance to really put it through solid testing. I'm just now starting up a new project that will be using my PCNC again, so I need to refresh that post to work with the latest release, and then test it a bit before it's something I would want other folks to trust. In the meantime, I could share my old post with anybody who is brave enough to try it out (no guarantees! it worked for me with my setup back when...). Let me know with a PM if you want it and are able to check the code it outputs before you break your taps, etc.
