586,068 active members*
3,735 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Anyone Used A Spin Indexer?
Results 1 to 11 of 11
    Feb 2006
    7063
    Has anyone here used a Spin Indexer? There are quite a few parts on the PDB and ATC that could use a spin indexer for fixturing. I've been using 5C collet blocks in a vise, but a spin indexer would be a much faster way of re-orienting the part. My only quesiton is: How is the spin indexer precisely aligned to the machine axis? The ones I've seen don't appear to have and ground reference surfaces that could be used for alignment.
    Regards,
    Ray L.
    Feb 2011
    353
    Re: Anyone Used A Spin Indexer?
    with the indexers that do not have the ground surface for alignment put a ground bar in the collet and tram the bar for alignment to your axis
    Sep 2006
    1738
    Quote Originally Posted by rcs60 View Post
    Ray, I was going to say the same thing. Depending on the length, maybe you'll need to constrain the end but perhaps you can get away with a large Dia. grounded rod which doesn't need to be supported at the end.
    Regards,
    -Jason
    Feb 2006
    7063
    Pretty much as I thought. Thanks.
    Regards,
    Ray L.
    Mar 2009
    336
    Ray,
    You can also remove the spindle of the spin indexer and indicate off the bore to cut your own reference surface that is parallel to the centerline. That way, you won't have to deal with the ground bar any more....
    "Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away." Antoine de Saint-Exupery (1900 - 1944)
    Jul 2007
    1602
    Ray,
    I am a bit late to this but another option might be one of these: Buy 225-205 Phase II Horizontal-Vertical Collet Indexer 5C Collet Indexers from UseEnco. They are more rigid than a spindexer and most have keyed bases.
    bob
    Feb 2006
    7063
    Quote Originally Posted by rowbare View Post
    Ray,
    bob
    But no indexing capability, which is the whole point....
    Regards,
    Ray L.
    Mar 2009
    336
    Ray,
    You may not be familiar with that style, but it IS an indexer (and a rather nice one). The lever on the left (in the photo) is used to turn it. It's been a long time since I've used one, but they are really nice indexers.
    Feb 2006
    7063
    Quote Originally Posted by HawkJET View Post
    Ray,
    Cris,
    I understand it can rotate, but is there really an indexer? I need to be able to rotate in precise 1 degree increments, and don't want to have to use some additional measuring tool to position it.
    Regards,
    Ray L.
    Mar 2009
    336
    Yes, it is an indexer, but if you need 1 degree increments, you're right. I don't believe it has that resolution. As I said it's been a long time (3 decades probably) since I've used one. As I recall, it has detents for something like 15 degree increments.
    Jun 2008
    1082
    Here's a similar, or maybe the same, unit. This description says it has 15-degree increments...
    Indexing 5C Collet Fixtures | Travers.com
  1. spin indexer
    By fourperf in forum Uncategorised MetalWorking Machines
    Last Post: 01-12-2011, 07:41 PM
  2. X3 Spindle won't spin
    By bergeson in forum Benchtop Machines
    Last Post: 05-20-2010, 05:42 AM
  3. Steppers don't spin, no hum
    By Gyvven in forum Hobbycnc (Products)
    Last Post: 01-31-2009, 01:38 AM
  4. Need to spin something in the Z
    By originator in forum Mechanical Calculations/Engineering Design
    Last Post: 01-10-2007, 02:05 PM
  5. Will a Cat 40 holder spin without a key?
    By moldcore in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2006, 04:19 PM
