I am machining my first very complex pattern and X3 seems to be waisting an extreme amount of time. It machines a little bit than retracts clearance and goes the other end of the work piece then back to the other side. It really makes me mad cutting air at feed rate not rapid, and jumping all over.
This tool path used surface high speed tool paths, solid model built in X3 solids.
My seat is legal with a dongle and expired maint. Level 3
Did I over look a setting some where or is the norm for $17,000 worth of software?
